Should i Bi Wire my centre speaker??
Discussion in 'Home Cinema Speakers' started by thepostman, Sep 30, 2004.
  1. thepostman
    thepostman
    Put quite simply as the centre speaker is so important carrying 70% of the sound will i really notice a difference if i Bi wire it??? :confused:
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Only as so far as replacing the brass speaker post connectors with the same speaker cable as your using to wire them up. Same results, much cheaper :smashin:
    I have mine bi-amped and im still not sure that makes enough difference to warrent the cost and space. I will play arround with it when im on holiday from work next week, and use MS. Dfours ears to help me decide if i have a rotel rb850 spare and some silver ani. cable spare:D:rolleyes:
