should db level gauge rise or fall in 3802 main set for sub
Discussion in 'Subwoofers' started by mick23, Jun 19, 2002.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    just tried new sub could not get a "peep" out of it because i had connected to s/w ext in rather than s/wpreout that solved set up db levels in main on screen menu, db level gauges rise and fall with the speaker settings, but when s/woofer level is set the "gauge" does not alter but a (rumble) does increase or decrease from the sub using denon 3802 just wondered why gauge does not rise and fall thank you
  2. Jase
    Jase
    Mar 16, 2001
    10,832
    United Kingdom
    +2,727
    :confused:
    The gauge should move up & down for the sub channel, dont know why it doesnt.:confused:
    Bit strange that.
  3. Guest
    Have you checked the batterys in your SPL meter?
