Shortlist of 2 1080p tvs LG/Panasonic, help plz
Discussion in 'What Is The Best TV For You?' started by scotty99, Jan 11, 2012.
  1. scotty99
    scotty99
    Sep 29, 2007
    22
    Narrowed down a budget choice of 32inch tvs. Main use will be ps3 gaming /films/blu rays etc.budget around £300 but could go to £330 at a push
    was going for this but price has just gone up this week by £30 (gets mainly good reviews, apart from weak blacks))
    LG 32LK450U 32" Full HD LCD TV buy online | Currys
    or this which is same price now as LG above, but I can't find many reviews on but gets a Which best buy apparently
    VIERA Flat Screen TV - 2011 LED & LCD TV - TX-L32U3B - Specification - Panasonic UK & Ireland
    What would you get/or Any other suggestions, many thanks in advance
  2. russ331
    russ331
    Dec 30, 2002
    634
    28
    +88
    The 32LK450 is £270 at Richer Sounds or £280 at Argos. Good TV. Good choice.
  3. scotty99
    scotty99
    Sep 29, 2007
    22
    Cheers mate, thanks for the heads up, I forgot about richer sounds.Just over £20 for 5 year warranty as well. Have you got a 32LK450?
  4. russ331
    russ331
    Dec 30, 2002
    634
    28
    +88
