Short throw vs. Long throw
Discussion in 'Projectors, Screens & Video Processors' started by sapkan, Oct 6, 2004.
  1. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    Having my Living room built right now so want to integrate everything for my home cinema at this stage. Considering a projector either the new Sony HS-51 or the AE700 Panny. I am a little limited on placement so want to know more about the short/long throw situation? Also heard that the Sonys can be placed off center, but how much so...? :lease: :lease: :lease: help
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Short throw means a short distance between projector and screen .. say 1-1.75 times screen width as a rough guide, long throw is the converse being 1.75+.
    That means the HS51 is certainly 'short', from the spec: " Short Throw Lens (100" < 3m)", ie. you could fill a 100" diagonal 16:9 screen (7'+ screen width) from less than 9'.
    I don't know the Sony but generally I think Lens Shift works at least 1/2 height and/or 1/2 width depending on what it's capable of. This means you could have the lens level with, say, the bottom of the screen and be able to shift the image to centre it ... though it's generally recommended not to use the full distance available because lenses can often be slightly imperfect at their extremes, and also light output can diminish at the extremes of shift.
    HTH
  3. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    ProjectorCentral is a mine of information, though not necessarily that great for reviews.
    Projector People has some good articles for those new to projector technology.
