short throw lenses
Discussion in 'Projectors, Screens & Video Processors' started by jason t, Aug 26, 2003.
  1. jason t
    jason t
    Mar 4, 2001
    1,571
    48
    kent
    +38
    hi i have a plv 30 and i need to increase the size of the image i can produce without knocking any walls down !! is there anywhere that i can buy a short throw lense from??
    thanks
    jason
  2. Anders_UK
    Anders_UK
    You could always try fold mirrors. I use these all the time, very simple to layout and use. Although there probably more aligned with rear-projection stuff so they are out of the way from little dirty pandies.
    Buhl do a load of lenses for LCD projectors not sure if your model is covered though.
  3. upallnight
    upallnight
    Jun 11, 2003
    1,769
    63
    watford
    +106
    is there a site with info to do this?
  4. jason t
    jason t
    Mar 4, 2001
    1,571
    48
    kent
    +38
    thanks for the reply
    where would i get a fold mirror??
    jason
  5. Messiah
    Messiah
    Apr 22, 2002
    7,543
    +338
    Anders
    I'm sure you live on a different planet from most of us :D Always informative though. :)
    link 1
    link 2
    link 3
  6. Anders_UK
    Anders_UK
    How?? and why??
  7. Messiah
    Messiah
    Apr 22, 2002
    7,543
    +338
    Hey Anders, it was a joke, hence the smiley. Because you often come up with some amazing in depth responses that most here would not have heard of let alone try. Great stuff though :)
  8. Anders_UK
    Anders_UK
    Check your user cp.
