Question Short throw 3D projector
Discussion in 'Projectors, Screens & Video Processors' started by maverick177uk, Sep 23, 2017.
    1. maverick177uk
      maverick177uk
      Jun 1, 2004
      5,726
      +1,299
      my head is getting mashed I’m really wanting to stick with a projector in my new soon to be built man cave, it looks like I’m going to have to orienter the room a certain way to fit everything in, this would necessitate a short throw projector. I love my 3D at home so could anyone recommend a short throw projector I’m looking at it firing from around 2 to 2.5m from the screen. I have an old Panasonic 2000 still going strong and the picture on that was tremendous it’s 10 years old now, so as long as it can match that quality I’d be happy.
    2. mike07
      mike07
      Sep 23, 2017
      7
      3
      Netherlands
      I recommend you Benq W1210ST.
      The image diagonal will be 100" at 2.5m distance from screen.
      The image is very good, and also is the 3D.
      It also have the best response time for a projector, 16ms, which is ideall for games.
    3. maverick177uk
      maverick177uk
      Jun 1, 2004
      5,726
      +1,299
      Cheers for the quick response, any ideas the size screen I could get at say 2m? Probably 92 inch I reckon I think I’ll be pushing it to get 2.5m just because of the wires.
    4. mike07
      mike07
      Sep 23, 2017
      7
      3
      Netherlands
      I gave you a wrong information in my previous post, the image diagonal is 100" at 1.5m distance from screen. At 2m diagonal will be 130". Cheers!
    5. maverick177uk
      maverick177uk
      Jun 1, 2004
      5,726
      +1,299
      Wow that’s huge even better
