Short Scart Cables?
Discussion in 'Cables & Switches' started by Spies, Aug 21, 2005.
  1. Spies
    Spies
    Aug 8, 2004
    300
    +10
    Is there anywhere that sells custom sized Scart Cables if not, or if its quite, can someone provide me with a Scart wiring diagram so I can cut my existing cables and re-solder them?
  2. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,305
    +100
    I suspect the Chord company and QED will supply you with custom sized cables if you ask.... may have to go through a specialist dealer tho' to do so.
  3. loadsofleads
    loadsofleads
    What size do you need specifically ?
  4. Spies
    Spies
    Aug 8, 2004
    300
    +10
    About 18" at most.
  5. loadsofleads
    loadsofleads
    Supra have the AV6.4 cables which are on the reel, which will carry RGB video and stereo audio, you can then purchase two supra scart connectors and build them to your specific requirements.
  6. CDphobe
    CDphobe
    Jul 11, 2004
    1,099
    48
    Bolton
    +81
  7. bri.s
    bri.s
    Aug 6, 2005
    284
    28
    Livingston
    +27
