Short or DIY RF cables
Discussion in 'Cables & Switches' started by simonali, Nov 21, 2004.
  1. simonali
    simonali
    Jul 5, 2004
    61
    I've just purchased an LCD TV for the kitchen and need an aerial lead for it. The TV will be mounted on the wall directly above the power and aerial outlets and, because of this, the cabling will be running down the wall underneath it. I would therefore like to keep the coax cable as short and neat as possible with a 0.5m length and a 90 degree connector at one end.
    Are there any suppliers of such a cable? I would be happy to make my own if this is not available. Any good suppliers for the parts?
