Shock absorber gone?
Delvey
Driving home from work and heard a pop. Hadn't hit a pot hole or anything. Noticed my steering was pulling to left. I've had a check of all 3 wheels and the only issue I have come across is the rear drivers shock absorber. The wheel hardly went up when I jacked the car either. Have attached a picture
un1eash
Yes that has gone. Replace in pairs.
Delvey
car-man
That isn't a failed shock absorber it is only the dirt shield, however it would be best replaced.
Keep looking for the reason why it is pulling to the left.
gangzoom
Yeaph that's just the dirty shield and bump stop behind it. Press down on the rear of the car, if it doesn't 'bounce' than the damper is fine :)
Delvey
Thought I'd risk it going to work and nearly ended up in a barrier. It feels like a wishbone or wishbone bush but there doesn't seem to have any play. Possible steering rack?
car-man
Do you still have the 406?
If you want it looking at this weekend I'll be happy to take a look for you without charge if you can get over my way.
Trollslayer
Get it sorted, you aren't able to control the vehicle.
Post 7 - great!
Delvey
Yes mate. And that would be great! Where about are you?
car-man
I think that's called a rear, lower horizontal stabiliser link bar.
I can find out in the morning where you can get one....it might be best to PM your reg number.
Delvey
Will do just got your Pm
Delvey
Part sourced from scrappers. It was utterly rotted and had no strength in it so I'm hoping this solves my issue. The rear tyre was way out of alignment. Massive thanks to car man for the help. Shows how top the members of this forum are
Delvey
And here is the offending part!
