Shift lens projectors
Discussion in 'Projectors, Screens & Video Processors' started by mechrekt, Apr 11, 2003.
  1. mechrekt
    mechrekt
    Can you show me a list about projectors that has the "shift lens" feature?
    I think this is an important feature (no digital keystone correction, but optical) when choosing a new projector to buy like me ;)
    When I'll have a good list of them I think I'll start comparing them to choose the better one. :)
    Thank you!
  2. Anders_UK
    Anders_UK
    Most new single chip DLP's have this feature. The amount varies from manufacturer to manufacturer and they all quote it in a different way too! Which is nice!
    Because of the optics and the nature of the reflective DLP chip, the light has to normally pass through a beamsplitter, which loses a vast amount of light, so to make them more efficient they have the chip offset at more than 100% so there is no need for a beamsplitter configuration.
    It is a very important feature, but because the offset is normally a percentage of image height then the amount (in MM) will vary with image size. Most hi-end projectors actually have motors to move the lens assembly, but cheapies have a fixed offset designed into them.
  3. Ice
    Ice
    mechrekt
    I know that the Sanyo Z1 has an optical lens shift feature. It is able to shift the picture both horizontally as well as vertically. I have seen it work, and it's quite impressive because:
    (a) it is easy and quick to use
    (b) there is no trapezoidal light overspill that you get with digital correction
    (c) no loss in picture quality.
    On the Z1, you can shift horizonatally up to 1/4 screen width and vertical shift is 1/2 screen height.
    Cheers,
    Ice :cool:
  4. LegalEagle
    LegalEagle
    Mar 18, 2003
    22
