DT79
We’ve recently decorated the lounge and as part of that I had all my AV and network cabling installed. Although everything seemed OK on paper, the new position for the hifi does seem rather closer than ideal to the stove, and as you can see I have my records stored at the bottom of the rack. The hifi cannot be located anywhere else.
They will not be subject to intense heat in this position but it will definitely get warm. During the winter when we use the stove there will be a metal coal bucket on the right hand side of the hearth, where the candle stick is currently, which will shield the records from directly radiated heat to a large extent, but I don’t want to take any chances.
I’m going to put a 12”*12” square of something in the bottom left of the rack to protect the records there. The question is what would be the best material to use (i.e. what will conduct the least heat?)
Wood? Polystyrene? Slate?
