Shielding a long VGA cable
Discussion in 'Cables & Switches' started by David Troughton, Apr 25, 2007.
  1. David Troughton
    David Troughton
    I am installing a long 12 m VGA cable in my lounge as part of a custom install for my projector. I am terminating the cable at both ends using a VGA face-plate. The wiring for the face plate doesn't have a connection for the cable screen. I rang the supplier who said this is not necessary to connect the screen. Given the length of the cable is this true? Should I connect the screen to the ground connection? Alternatively I could connect to screen to the house earth. Should I put ferrite cores on the cable?
    The specification for the face-plate that I have purchased is provided here:
    http://www.keene.co.uk/electronics/multi.php?mycode=HCP21QC
    David
  2. Stung
    Stung
    Dec 4, 2006
    183
    +14
    Connect the cable screen to one of the nuts of the VGA socket behind the face plate. That will sort it.
    Edit: I just had a closer look at the picture. There is a ground connection - GND. You can connect the screen to GND or like I said to the nut on the back of the VGA socket.
