Shield Season 4
Discussion in 'TV Show Forum' started by Solomon Grundy, Mar 22, 2005.
  1. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    12,864
    oop north.
    +2,407
    Does anyone have any news as to when this will air? Iam getting serious withdrawal symptoms.
  2. Mindcrime
    Mindcrime
    Jul 27, 2000
    998
    46
    Edmonton via Birkenhead, UK
    +119
    It has just started down in the States, so I guess in about June, same as Season 3 last year.
    Think yourself lucky though as over here in Canada we are only just getting Season 3:thumbsdow Thankfully, I had caught a few in the UK last June/July but I can't believe I have to wait another year for Season 4:suicide:, I guess the box set will be out before it is aired!!
  3. smelly
    smelly
    Oct 16, 2004
    1,598
    Bristol
    +102
    I'm not thinking its going to be very soon sorry :( its only just aired in the US - first ep of series 4 was aired on 15th March.
    There's some info on DVD Times on series 3 and when the DVD is due for release - that may help any withdrawal symptons ;)
    http://www.dvdtimes.co.uk/content.php?contentid=56359
  4. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    12,864
    oop north.
    +2,407
    I guess I'm just going to have to make do with an episode guide and a vivid imagination for the time being...aaaarrrggghhh!!!
  5. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    Series 3 starts 13th April 10pm FX289 (it'll have to do for now, better than nothing). :smashin:
    Have you tried "The Wire" on FX289? I've seen trailers whilst watching re-runs of NYPD blue, I'm going to give it a try tonight.
  6. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    The Wire is not really a show you can dip in and out of, the whole first season is a a single story so perhaps not a good idea to start with episode 11 out of 13 :)
    If you like it then you'll know the shape of the ending before you get to see the start and if you don't then you can never be sure if you had watched the opening eps which set the scene if you would have enjoyed it.
    Your call though:)
  7. backtothefuture
    backtothefuture
    what channel does The Shield usually air on in the UK? is it only Fox? ie dont Sky or any of the terrestrial channels show it?
  8. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Five has had the UK premiere from season 1 and I expect they will be showing season 4 later this year.
    FX have the pay rights and are showing season 3 with season 4 probably next year, not sure if Five by the complete rights and then sell them on or FX bought buy direct from the distributer.
    The Shield along with 24 were the shows SKY1 were kicking themselves for not buying them from the start:)
  9. backtothefuture
    backtothefuture
    so is five showing season 3 currently?
  10. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Nope, they showed it last year.
  11. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    Cheers. I'll give it a miss this time round. I've only just returned to Sky and FX wasn't available on Ntl (although I beleive it is now) so didn't have any idea where the shows were upto.
  12. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    12,864
    oop north.
    +2,407
    resurrecting this thread, any news on S4 yet? I can't even see the R2 DVD of season 3 available anytime soon...
  13. NoEntry2k
    NoEntry2k
    Mar 26, 2004
    147
    +13
    Nope, still waiting in both cases!
  14. texasboy
    texasboy
    Sep 16, 2002
    390
    +15
    does anyone know when season 3 of The Shield will be out on Region 2 DVD?
    I know you can already buy the Region 1 version of Season 3, but it's only 4:3.
    Season 1 and 2 were the same
    Thx
  15. hardiz
    hardiz
    Mar 3, 2005
    246
    +22
    i think the new season we be on in late july/august,(on five) that is the time the series 3 dvd will be out in the uk
  16. Solomon Grundy
    Solomon Grundy
    Nov 1, 2004
    12,864
    oop north.
    +2,407
    that is really not good news...
  17. PoochJD
    PoochJD
    Aug 28, 2000
    10,992
    Norwich
    +1,862
    As I've explained before "The Shield" (Season 4) will air on Five in the UK, in the next 2-4 weeks. It's more than likely taking over from where either:
    - Law & Order: Criminal Intent is currently airing on Saturday nights around 10pm, or
    - maybe 10pm on a Tuesday night, after "CSI: Crime Scene Investigation" airs.
    Pooch
