sherwood vs sony
D
damien
i have just bought a sherwood rd 6103 D.D D.T.S amp from richer sounds and i need a little help setting up as the instructions are not verry helpful i am running the amp off a sony dvpns 700 dvd player through the 5.1 audio jacks. Would i be better running through the optical or coaxle? the amp has 2 co-axle and a single optical which i am using for my x-box any help would be GRRREEEAAATTTT thanks for your time xxxx xxxx xxxx xxxx
lynx
Use one of your co-ax cables to connect from the co-ax digital out on the player. ;)
