Sherwood RX-1010 static
Discussion in 'AV Receivers & Amplifiers' started by jonnym, Jan 16, 2005.
  1. jonnym
    jonnym
    Jan 16, 2005
    3
    Hi there.
    I have a Sherwood rx1010 amp/receiver that has recently stopped working properly.
    When turning up/down the volume on the amp i get a lot of static through the speakers.. However, the sound is fine once the volume has been adjusted.
    Has something has blown in the amp? I don't know very much about amps, just wondering if anyone knows what is likely to cause this, and whether or not its worth repairing? :)
    Many thanks
    Jon
  2. jonnym
    jonnym
    Jan 16, 2005
    3
    anyone? :(
  3. jonnym
    jonnym
    Jan 16, 2005
    3
    Is it something to do with the volume control? As even touching it causes the static noise to come through the speakers.
  4. garyroboff
    garyroboff
    Jan 18, 2004
    13
    USA
    You should call or e-mail Eugene Chavez at Sherwood America (Gene runs Sherwood's technical services department). His e-mail address is Eugene@SherwoodAmerica.com, and his telephone number in California is (562) 741-0960 (Ext. 115). He'll be able to help you resolve the issue.
  5. Teamscoop
    Teamscoop
    Mar 4, 2005
    163
    Southern UK
    +4
    ..I've been looking for someone who knew diddly about the Sherwood range :hiya: .
