Sherwood RVD-6095RDS Loss of memory pre-sets
Discussion in 'AV Receivers & Amplifiers' started by Alex Leary, May 28, 2005.
  1. Alex Leary
    Alex Leary
    I have used the above model Audio/Video receiver for over 3 years until now, with no problem. In the last week it has lost all of the station and volume/bass/treble settings each time it's switched off. I've reset them 3 times, and left it in in standby mode for 3 nights, but as soon as it's switched off completely, all settings are lost.
    Is anyone aware of a reset, or an internal battery that may need changing ?
    Thanks.
  2. garyroboff
    garyroboff
    Jan 18, 2004
    13
    USA
    Many receivers use a capacitor instead of a battery, and there may be a problem with your unit. Send an e-mail describing the problem to: Eugene@Sherwoodamerica.com (Gene runs technical services at Sherwood in Los Angeles) and he'll advise you on the probable cause and the best approach to repair outside the US. Good luck!
  3. Alex Leary
    Alex Leary
    Thanks for this. Had found your man on a Google search, and am hoping for a reply soon.
  4. maknight
    maknight
    Hi Alex,
    I've had the same problem with my Sherwood amp, what was the resolution?
  5. CatManDo
    CatManDo
    Nov 5, 2003
    1,754
    South Yorks
    +242
    I have the same amp and suffer the same problems! If I have a power cut then I lose all my settings. I just leave the unit on standby all the time.
    Me needs a Denon!
  6. oatmeal
    oatmeal
    Oct 12, 2002
    1,635
    38
    Home of the worst postal system in the world.
    +15
    I also have now suffered an identical problem. There has always been power available to the unit (I've never unplugged it for more than fifteen minutes) but all pre-sets have gone.
    It's as if an internal battery has given up the ghost.
    Did anyone ever find a solution to this?
  7. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I have an older Sherwood that does this. I've scoured the main board for a battery or a large capacitor, and never found one. I suspect that there is another board tucked away behind the front panel, but so far I've not had the time to look.
  8. garyroboff
    garyroboff
    Jan 18, 2004
    13
    USA
    Do you have the service manaual? If not, you can obtain one from Sherwood America, 13101 Moore Street, Cerritos, CA 90703, U.S.A. Eugene Chavez, service manager, (562) 741-0960 extension 115 or eugene@sherwoodamerica.com, can tell you where the capcitor is and can help diagnose your problem. Sherwood factory service is excellent in the USA, not sure about the UK.
