sherwood rd8108rds info
Discussion in 'AV Receivers & Amplifiers' started by ewin, Aug 14, 2003.
  1. ewin
    ewin
    Feb 25, 2003
    123
    16
    scotland
    seen it in r.s and it has dd ex,proL2,dts es,neo.6 has antone got one to tell me how good it is or what a load of crap.
  2. adesonic
    adesonic
    Jan 28, 2003
    65
    Manchester
    Had one for a day from rs - it was fine for movies, awful on music and developed a fault on the Front Left Channel within 24Hrs - took it back and got the ARCAM AVR100 cheap from discontinued stock (much much better on music). I use my kit 50/50 music and video - if you are cinema only, you might find it fine.
    Apparently Sherwood make the Marantz kit (according to the guy at RS)
  3. hamtaro
    hamtaro
    sherwood and marantz dont have anything to do with each other! another classic richer sounds sale patter porkys
  4. mjn
    mjn
    May 24, 2001
    21,881
    Herts, England
    +9,576
    thats a new one!!
  5. phillym
    phillym
    actually he's not a million miles off. some marantz lines are made in the same factory as the sherwood gear. sr6300 is on that i recall. some denon stuff also comes out of the place!!
  6. Majik
    Majik
    Jun 10, 2003
    193
    Coventry
    I'm not sure it's entirley comparable, but I have a Sherwood RD6108RDS which I am very happy with. Hasn't failed me yet and sounds pretty good for the price.
    Majik
  7. adesonic
    adesonic
    Jan 28, 2003
    65
    Manchester
    There is another post on here somewhere about crackling left spakers on set ups involving Marantz amps. I used to work in a factory that was part of an electronics manufacturing services company (i.e we made stuff for other firms that had their badge on it - e.g dell, nokia, sun, and many others). Obviously, the same manufacturing techniques and many common components went into all these different products (the designs were of course different).
    Could it be that if some Marantz/ Denon and Sherwood kit is made by a common contractor, that contractor has introduced a common fault across the various makes?
    Makes you wonder don't it!
