SHELLY & ROTARY DIMMER
TheSceptic
Hi everyone!
I've been reading about this topic a lot and it's driving me nuts so I need a final answer.
I have to say that my electrical knowledge is nowhere near that of the group here, so please be merciful ;)
So:
As part of our renovation, we will install rotary dimmers for various lamps/lights.
My goal is:
1. Control Lamps (LEDs, ceiling lamps) via the ROTARY DIMMER in the wall to: a) dim b) switch on/off. (No problem, that's exactly what the ROTARY DIMMER is built for)
2. Switch these lamps on/off with a SHELLY.
It would be nice to be able to dim with the Shelly as well, but that doesn't seem possible if I understand correctly.
So ask:
How can I reach my goal?
My rotary dimmer is "Push ON/OFF rotary dimmer with 3 way switching" (has 1 knob that turns on and off when you turn it)
Seb Briggs
You can’t use rotary switches with Shelly or any other smart device that I am aware of .
Better to use 3 way centre off retractive switches if you want dimming control at the switch
TheSceptic
Even if all I want the Shelly to do is to turn on/off?
The Dimming would exclusively happen with the manual dimmer..
Seb Briggs
unfortunately yes. A rotary switch is a rheostat that increases and reduces electricity as it’s turned. This is incompatible with Shelly as the switch sits in between the light fitting and the Shelly device so the increase and decrease would have no effect on the bulb and could end up damaging the Shelly module
Maverick567
You can’t use a rotary switch due to how they work. Aurora make a Zigbee dimmer which fits the bill for what you need. It’s excellent and incredibly reliable.
Maverick567
If your totally set on the Shelly you could probably use the battery version of the Aurora dimmer and combine them in Home Assistant or similar. So the Aurora would just become and input device that adjust the dimmer settings.
Samsung S95B QD OLED Review - A Quantum Leap for OLED!
