Shelly Dimmer 2
dave77
Joined
Nov 22, 2007
Messages
2,296
Reaction score
476
Points
439
Location
Leeds
The Shelly Dimmer for non-neutral wiring finally came out recently, has anyone on here used them yet?
Interested n your thoughts as well. I have Shelly 1’s and 2.5s currently.
The 1 and 2.5 work well with Homeseer. Normally if they work well on your 2 platforms they should be good with Homeseer. I may also grab one to try, but need to finish my review of the Ajax alarm system that they sent me first.
Arrived quicker than I thought
So far used the Shelly App to add the dimmer 2 went well and certainly better than my experiences with Sonoff.
Connected a retractive 2 way centre off switch and a LED dimmer, wired similarly to a Fibaro dimmer, this means i can control dimming and on/off either by the app, a scene or via the physical switch which I think is important.
Brief attempt at adding to Hubitat without success but thats probably my knowledge of Hubitat as only had the Hubitat evolution for a week.
Next stage is the Fibaro integration which looks easier and will try that this evening
Do you mean a 3 position switch, if so did you just wire SW1 to L1 and SW2 to L2? I haven't had chance to fit mine yet as I need to put in deeper back boxes too.
How are you finding the dimming, is it responsive when you hold the switch?
Yes 3 position centre off retractive . Ie one click up for on one click down for off . Hold for dimming or brightening
Yes l1 in switch port 1 l2 in switch port 2. Common live
Just installed mine, decided to go with a spacer for now rather than deepening the back boxes.
Responsiveness is perfect, bearing in mind I currently have Lightwave switches which take 3 seconds to react to a button press, Shelly is almost instant!
Yeah, Click Scolmore GridPro's
I'm surprised there's no maximum level you can set for dimming, hopefully they'll add that in future.
Similar to my test rig then, I’m using varilight but exactly the same grid based system
today’s task if I get time is to test 2 way switching
I'd be interested to know how that works with 3-pos switches, i'll need to do the same when I get around to the hallway/landing. For now i'm just doing the rest of the single switches so I can finally see the back of those useless Lightwave switches!
If anything like Fibaro its very straightforward as wired in parallel, fingers crossed!!
We have created some guides for Fibaro wiring, so hope to do the same for Shelly
This is the one for the Fibaro dimmer
Seb
Ah, I was thinking you'd need a Shelly at each switch. So will that need an extra wire between switches compared to a standard light switch?
for 2 way with 3 position yes it will need 3 wires.
For 2 way when only two wires in place you maybe better using toggle switches, though maybe you could use a 3 position at one end and a toggle at other position
More testing
Seb
EDIT : That method does works fine ( i forgot to change the switch type in the app :facepalm:)
Just realised I had mine set to leading edge dimming, set to trailing now and re-calibrated and they seem even better, and brighter! Really need that max setting, I switched to 10.5W bulbs to avoid needing the bypass and only need them at 60% max
These work well and seem good value for money if it helps anyone
Amazon product ASIN B0727Q8YLQAmazon product ASIN B06Y3JLR11
This looks interesting, I wonder which rotary switches are compatible
Even more interesting, ive just updated the firmware and the rotary switch option has disappeared
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
