Shelly 2
Discussion in 'General Tech & Gadget Forums' started by frund, Dec 27, 2018.
  1. frund
    frund
    Aug 1, 2005
    Mid Wales
    +3
    Shelly 2 looks like the unit I need to remotely control my central heating when abroad etc.
    I can see that 2 relays can be controlled independently by manual switch or [Android phone in my case] eg on manually off remotely or vice versa. Not being the worlds best with electronics but quite capable domestic wiring. Here is my question.
    In order to work the relay manually can I use a toggle switch like a ordinary on off or does it have to be a momentary switch [for 240v ? where would I get one]
    I intended to wire boiler with control panel with indicator showing when on or off with Shelly 2 somewhere inside. Relay 2 switching, already working, Honeywell controller for gravity domestic hot.
    Any advice welcome.
  2. frund
    frund
    Aug 1, 2005
    Mid Wales
    +3
    Having done a bit of reading the momentary switch would appear to be the one. I will toggle live supply 1 boiler 2 thermostat with manual hot water switch. All with indicator lights it will be like Christmas.
