Shelf Hight On Toshiba Zp18
Discussion in 'General TV Discussions Forum' started by perry ferrit, Apr 2, 2002.
  1. perry ferrit
    perry ferrit
    Have orderd the tosh 36zp18 and the set is due on wen or thurs and it has just occurred to me, i am not sure if my centre speaker will fit on the top shelf of stand. Does any one out there have the same set (daft question) if so could you please measure the hight of the top shelf (from shelf to underside of the set) and let me know.
    Thanks alot........:confused:
  2. £note
    £note
    Jan 21, 2002
    146
    Isle of Skye
    +13
    600mm
  3. plb
    plb
    I have the Mission M7C in silver sitting on the top shelf of my 36" Tosh.
    (Just about fits)
    Paul
  4. perry ferrit
    perry ferrit
    PLB, What is the hight from shelf to underside of tv inches or mm ?
    Thanks alot......;)
  5. perry ferrit
    perry ferrit
  6. £note
    £note
    Jan 21, 2002
    146
    Isle of Skye
    +13
    Space between top shelf and tv is 60 mm.
  7. perry ferrit
    perry ferrit
    Thanks alot for that mate, any probs worth checking for ?:D
  8. Doubledoom
    Doubledoom
    The Tosh ZP range is probably one of the most discussed television sets in this forum. There was another thread on the shelves in the last two weeks (amongst others) which you may want to check out.
