I don’t sit off axis and both my left and right seats are only around 12 degrees so don’t expect much difference here tbh.Off-axis response will be better now with your SAM centre, Mark, according to the specifications. See how it sounds and if you notice a difference off-axis. Did you get some baffles to elevate your horns? I think that is a good idea, too. Well done on completing your matched LCR
Best
I think I’ve got a solution to keep the speaker centrally, likely to run the bass driver on its side with the horn vertical, both bang in the middle of my screen.
