Shed Insulation
Discussion in 'General Chat' started by daftpunk1, Mar 3, 2013.
  1. daftpunk1
    daftpunk1
    Jan 11, 2010
    1,870
    38
    +19
    I am going to be insulating a shed within the next month. Ive planned to use foam polystyrene sheets, its called styrofoam. Im not too sure whether or not to use plywood or hardboard to panel over the poly sheets. Ive seen this oil tempered hardboard but not sure if I can get this oil hardboard, must phone my builders merchant to see,
    Ive read that polystyrene can be a fire hazard for shed insulation and if Im running electric to it, it can perish the cable. What Ive not read is the logic behind it, how could this happen.
    Im not actually using polystyrene, ive read that the foam polystyrene is a far better insulator and better moisture barrier so maybe these comments dont refer to the foam poly...
    Also read alot of people using mineral wool but do not like this stuff...
    I may consider switching to plasterboard as Im thinking I could paint this with some left over paint I have, I think plasterboard will take paint better than hardboard...
    Anyone tackled something like this before...:thumbsup:
  2. Wahreo
    Wahreo
    Oct 11, 2012
    15,333
    +12,506
    How about a bit of OSB?
  3. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    oiiiiii PCthug where are you :smashin:
  4. danmc_82
    danmc_82
    Jan 19, 2007
    5,627
    Skynet Border
    +1,206
    I'd be happy enough using standard polystyrene for insulation, it just means you will have to cover with fireproof board. Styrofoam IS polystyrene, just a different name.
    You can get extruded polystyrene which is a better insulator, but more expensive.
    If your worried about flammability then mineral wool is the way to go, plus its cheap.
    You can get around the electric cable bit by using trunking and burying it into the polystyrene.
  5. DOBLY
    DOBLY
    Oct 30, 2006
    1,736
    116
    Dunedin
    +657
    You can use actual, proper, real wool instead - click here
    might be a bit over the top for a shed though.....
  6. Thug
    Thug
    Jul 17, 2003
    7,692
    3
    Middlesbrough
    +3,736
    Lol.
    I am still insulating my shed.
    I have done the walls, floor and part of the ceiling using glass fibre loft insulation.
    This is fire proof (has to be to meet guidelines) and very cheap (especially this time of year).
    I still need to finish the roof off and was looking at polystyrene sheets but it may still be more expensive than glass fibre rolls. It will be easier and cleaner to work with.
    As I said, I have only done part of my ceiling, this was due to the small area I have done so far being difficult to do alone and I also breathed some of it in which was uncomfortable and it also made me itch like crazy.
    I have lined the inside of the shed out with plasterboard as it is very cheap (about £7 for a 8'x4' board) compared to wood. Just make sure its bone dry in there (which mine is).
  7. daftpunk1
    daftpunk1
    Jan 11, 2010
    1,870
    38
    +19
    I would have thought doing the ceiling would be hard using rigid material. Its the part im not looking forward to.
    If we were not moving in 3 years i would skim it and paint it so it would look like a proper room but would be too much hassle when it comes to dissasembly.
    Yeah im def sticking with polystyrene, might put some aluminium tape over it, will probably use 12mm ply to panel over it.
    Similar approach for the floor, plastic lining, polystyrene then tongue and groove boards....
    The ceiling is going to require the most thought, as i have lights to think about as im running electric out to it...
  8. nacmacfeegle
    nacmacfeegle
    May 1, 2008
    3,719
    Auchenblae
    +1,488
    For a shed, I'd go with OSB lining, Plasterboard is fine but not as robust. I guess it all depends on your use, in my shed I'd end up bashing the snot out of plasterboard. Just the way that the kids chuck bikes, garden toys, etc in there
    IIRC PCThug's shed is more of a darkroom / photo studio? So not likely to see the same level of abuse.
  9. saintie1
    saintie1
    Aug 30, 2010
    397
    43
    highland
    +115
    Do not run bare cable through the polystyrene, it will knacker the cable and increase the risk of a fire. Run the cable through conduit (it is cheap and readily available). The logic of it doesn't matter just don't do it. Conduit is cheap and should you want to run additional cable or replace it in the future, it is very easy to do.
