I'm building a shed which will have half of the space allocated for fitness (weights, cycle, etc.).
Planning a concrete base with 2x4 timbers for the flooring with 18mm plywood or OSB over. Just wondering what to do in the corner with the 'gymnasium' in terms of strengthening the floor to withstand a heavy-ish bashing. Would doubling up on the floor joists/noggins be adequate? To damp noise I can also put a rubber mat down?
