Sharps new 5E Range - How Long?
Discussion in 'LCD & LED LCD TVs Forum' started by Black Custard, Jan 22, 2005.
Tags:
  1. Black Custard
    Black Custard
    How long do you reckon it will be before Sharp decide that they have made a massive cock up by disscontinuing the 3E model and replacing it with the 5E
    The 5E having no HDCP compliant DVI socket makes it incompatible with Skys HD offering, and leaves the 5E range as a massive white elephant.
    Surely no manufacturer should be downgrading the connection compatibility that they are supplying on their latest models, instead they should be ensuring DVI and HDMI connectivity is a must.
    Someone should inform Sharp about this :rolleyes:
  2. jimg
    jimg
    Jul 4, 2004
    826
    +58
    This topic has been done to death, but here we go again!
    The plan was to have a family of units i.e 1E, 3E, 4E and 5E with the 5E being a lower cost unit. Unfortunately in the 32" size all the 3E and 4E models seem to have sold out. There are still 26" and 37" units around, I guess you wanted 32"?
  3. andya
    andya
    Oct 25, 2002
    2,432
    48
    manchester
    +35
    i think they will come back soon ,france germany e.t.c still have them and they come from the japan production line i think its because a new factory in spain has bee set up sp its cheaper than sharp getting them from japan anyway i here that the 32ga4e is available again
  4. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    The GA5 has not replaced the GA3 model although it does look that way. All 3 GA models (3/4/5) are of the same group and should have been on display to sell at the same time. For some reason the GA5 got delayed and by the time it got here, the GA3 and 4s were bought up. The GA5 was on the cards way before Sky made their announcement.
    If you're looking for another White Elephant, check out Sony's new 32", no DVI or HDMI.
    Richie.
  5. Freeloader
    Freeloader
    Jan 11, 2005
    4
    Leicester
    Have just found a 37GA4E and purchased it - but dealers are all saying that they do not expect new stock of the 3 or 4 - they think these models are discontinued. :confused:
  6. Yaka
    Yaka
    Dec 20, 2000
    1,742
    2
    63
    +130
    where did you find it?
  7. Freeloader
    Freeloader
    Jan 11, 2005
    4
    Leicester
    Sound & Vision 01204 861 861, but it was the last one they had in 37in.
