Quantcast
Sharpness control on FX70U
T
Tony_Anon
Does anybody know how to change the sharpness control on the Sony 32" FX70U in 'Personal' mode?! I can change brightness, contrast and colour but not sharpness. i.e. I can't select sharpness as it's not highlighted. It's fixed in 'Live' and 'Movie' mode.
Cheers.
HowieC
Sharpness will grey-out when you have a RGB input, the cheat to adjust sharpness while watching an RGB source is to.....
Select an analogue chanel, then go to menu and sharpness, with the sharpness bar on screen change to your RGB source and the sharpness adjustment should still be available.
