Sharpness and Hue on BD808s?
Discussion in 'Projectors, Screens & Video Processors' started by cj, Aug 11, 2003.
  1. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    I know this is a bit of a noob question, but why do the Sharpness and Hue button on my BD808s remote not do anything? Are they supported on any Barco models?
  2. RichardA
    RichardA
    cj,
    I think you'll find that they apply to certain input types only.
    Certainly the Hue control will only have an effect on a Composite NTSC source.
    I'm guessing (and hoping) that you are using a signal better than NTSC so it won't work in your installation.
    hope this helps!
  3. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    Ah now I see. Yes I'm using a component output from a TMA PSM192 module. Thanks.
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    They will only work when the signal goes through the projectors decoder. So composite, s-video or component. You are sending it an RGB signal. therefor bypassing its decoder.
