sharp z91
Discussion in 'Projectors, Screens & Video Processors' started by pal, May 27, 2003.
  1. pal
    pal
    May 27, 2003
    183
    coventry
    +14
    Can anyone tell me the screen (width and height) from a throw of 9ft.
    Regards,
    Pal
  2. Kramer
    Kramer
  3. pal
    pal
    May 27, 2003
    183
    coventry
    +14
    I had tried projectorcentral-however that only gives the calulations for the z90.
    I understand the z91 has a shorter throw lens.
    Pal.
  4. Kramer
    Kramer
    OK - didn't know the Z91 wasn't listed. Must be a very new or European specific model.
    Should be up soon though.
  5. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    I have seen this PJ on saturday...all i can say is .....amazing BIG picture and i sat about 12 feet from the screen i would have thought is was easily 3 meters in width......it was really MASSIVE...and to top it off......i did not see ONE rainbow !
    I'm going back on saturday to see it again.....just to reassure myself, and to play with it ( if i'm allowed ) this time !! Also will see it next to the AE300 to compare.
    These PJ's are on my VERY SHORT LIST of 2 PJ's !!! And as you can see they are both on it !!! LOL
    :smashin:
  6. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    I measured the distance of the PJ last saturday. It was about 15 feet away from the image which was a good 80 - 90 inches.
    Obviously, to make the picture smaller you move the PJ forward and zoom in.
    Hope this helps slightly.
    CB.
  7. KeithO
    KeithO
    May 28, 2003
    1,434
    63
    Erding, Bavaria
    +214
    Yes the z91 is exactly the same as the z90 but with a shorter throw lens. If you want to use the projector calc Kramer mentioned, you need to know that the z91 is called the Sharpvision Theago DT-200 in the USA
