Sharp Xvc20e
Discussion in 'Projectors, Screens & Video Processors' started by Oliv83, Mar 29, 2002.
  1. Oliv83
    Oliv83
    I want to buy a first video proj and find one (occasion) for arround 700 $ US.
    Does this a good Video proj to start with ?
    What's about the price ?:rolleyes:
    Where can I found info about it (URL, tip & tricks)
    What's could you advise me
  2. jrwood
    jrwood
    I think it would be better to wait a bit longer and save for another budget projector like the Panasonic or wait a bit and see what other manufacturers bring out. The projector specs for the Sharp seem very bad and will only produce a 60" image at best with a lumen rating of 60!..yes 60 not 600!. Also the bulb seems expensive to replace for such a low lumen rating.
    http://www.homecinemachoice.com/testbench/VideoProjectors/Sharp/SharpXV-C20E.shtml while it got a favourable review at the time projectors have improved A LOT over the last few years let alone 5 years ago.
    James
  3. tahustvedt
    tahustvedt
    Feb 11, 2002
    112
    19
    In a galaxy far, far away... (Norway)
    Basically, it's crap! :)
    I looked at these too whan I was looking for my first projector. I never had a chance to see one for myself but look at the specs:
    480x400 resolution
    60 ANSI-lumen
    only composite and s-video
    The bulb is insanely expensive, around $700 I think. I have a friend who worked as a tech on these.
    The C20E doesn't support anamorfic 16:9 but it doesn't matter because the resolution is so low. That's how low the resolution is! :)
    I recommend you look for a used Sony VPL-CS1 or CS2 instead. They probably go for around $1000 and up. The Sonys support component in too. A Sharp XG-NV1E (NV1U for US-models) can probably also be found for $700 or less. That's a much better projector than the C20E, and it has a 832x624-resolution.
    Tor Arne
  4. Oliv83
    Oliv83
    I'm going to surch a new one ! ;)
  5. jrwood
    jrwood
