Sharp XV-Z90E Question
Discussion in 'Projectors, Screens & Video Processors' started by MattH, Feb 27, 2003.
  1. MattH
    MattH
    Oct 1, 2002
    101
    Broxbourne, Herts
    +5
    Am thinking of buying this projector, will have to mount it on the ceiling about 15 to 16 feet from the screen, can anyone help me with the width of the image that I will get, I have looked at projector central but they only have the specs for the US version.
    TIA
  2. JRPaynter
    JRPaynter
    Matt, divide your throw by 2.5 to give you the widest image and 3 to give you the smallest.
    It's a good PJ and even better with an iScan pro.
    Jeff Paynter
    Horsham Hi-Fi & Home Cinema
  3. BoG
    BoG
    I have an XV-Z90E which I am very satisfied with. The iScan Pro seems expensive for what it does. How would it compare to a PAL progressive DVD player for instance?
