Sharp XV-Z1E: replaced lamp, color filter has a dark area
Discussion in 'Projectors, Screens & Video Processors' started by easy, Mar 4, 2005.
  1. easy
    easy
    Hi there!
    I just replaced the bulb (after ~ 2100 hrs) in my somewhat aged Sharp XV-Z1E. Light had diminished and the lamp reflector looked quite bad ;)
    Now the light is much better and my nerves aren't that stressed anymore.
    BUT: There is quite a large dark area on the blue color channel that drives me crazy. Since it's only on blue, I don't suspect the LCD panel. Could some blue color filter have become darkened or burned? :confused:
    AND: I tried to open the proj but didn't manage beyond the back end lifting a little. Does anyone know how to open that critter or have access to Sharp repair documents? :lease:
    Otherwise I will have to :suicide: for investing into the replace lamp.
    Thx a lot :hiya:
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,084
    UK.
    +3,486
    I think there are 3 LCD panels, so it's possible that the blue one or the polariser for it might be damaged. I don't know much about LCDs, so maybe someone who does can expand upon that a bit more.
    Gary.
  3. easy
    easy
    Thx for the quick reply, Gary!
    3 panels sounds reasonable to me. I hope it's not completely :zonked: in that area.
    If i just could crack that thing open. :mad:
    (btw. just saw your ht pics and instantly recognized the familiar denon face *g*. i have a avc-3800)
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    14,084
    UK.
    +3,486
    I think the individual panels or polarisers can be replaced, but it's probably not cheap.
    I like the little Denon, seems to do a reasonable job. Would like to hear how the 3805 sounds with it's self calibrating do-da though. :)
    Gary.
  5. ptek
    ptek
    Most likely is blue polariser filter in front of blue LCD which will be
    uv damaged (burned), on a white screen it should show like a yellow
    patch, unlikely that the panel is damaged
