SHARP XV-370P projector
Discussion in 'Projectors, Screens & Video Processors' started by jjcool, Aug 14, 2004.
  1. jjcool
    jjcool
    anyone heard of the SHARP XV-370P projector, i heard its about 2 years old,
    this projector any good? seen one for sale in my local porn shop.
    i meant porn as in pawnbroker lol :D
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    jjcool,
    Hi.... I sincerely hope that your local porn shop sells porn...................... :D while your local pawn shop might indeed have a projector from time to time..... :oops:
    Anyway, if the projector you're referring to looks like This One, then it's a hell of a lot older that 2 years old, more like 7 or 8, it probably predates the three-panel LCD models from Sharp (such as the 380H), and that was about in 1997...... In the mid to late 90s Sharp had a wide range of LCD projectors in the home cinema market It might be worth having for curiosity sake..... it has a single LCD panel in it, but you should bear in mind that the replacement lamps are about £275 + VAT.
    Have a look at This One or This One on eBay and see how the seller gets on, might give you an idea of how much the market thinks they're worth. The second ad includes the following gem :"Features include: A newly developed, high-reliability, high-contrast (100:1) LCD panel," :rolleyes: , doubtless culled from whatever blurb is available for the projector.............. by comparison to projectors available for the last couple of years, it'd probably look cack. If there was loads of life left in the lamp and you were getting it at a real bargain price it would get you watching a big screen but.................It really depends on the price..............
    If you wanted to get into front projection at a budget price, then a secondhand AE100 or similar from the For Sale forums here could be yours for about £400 from time to time, or if you could stretch to about £560, there's a thread showing you how to get your hands on a new Infocus X1 for about that price. Either would be a very decent starting point, and imo, far preferable to the Sharp in question.
    How much does the pawn shop want for it ?
    All the best.
    Sean G.
  3. jjcool
    jjcool
    they want 320 quid for it.
    i did ask about it, they said the picture is good, very clear and colour is very good.
    i asked about the lamp life was used thay said around 390 hours,
    i dont know alot about projectors but i did ask what was the contrast ratio, but they never had a clue so.
    if this is old then surely the picture is rubbish being 7 or 8 years old?
    this will be my first projector, but i know im looking for somethink to,
    play my console on, dvd, cable box,
    watch 4.3 and widescreen
    watch it on a 90 to 100 screen.
    not sure if this projector meets my criteria.
  4. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Well I wouldn't pay £320 for it................
    I doubt that this is the projector to suit your requirements - have a look abou the forum and see what others are talking about, go see them in action and judge from that.
    Sean.
  5. Kramer
    Kramer
    If you did, I'd be your first visitor in your new home, the looney bin :D
    No doubt some poor soul will part with some cash for it though :(
