SHARP XR-10X not displayiong component image
Discussion in 'Projectors, Screens & Video Processors' started by HTMD, Sep 14, 2007.
  1. HTMD
    HTMD
    Hi Everyone. I have a SHARP XR-10X Video Projector that I am trying to get to work with a Philips DVD player that has a component Progressive scan output on the back.
    On the DVD end of the cable I have the three component RCA jacks color coded Red, Green and Blue (Which I have plugged into the corresponding Red, Green and Blue Outputs on the back of the Philips DVD player) and the other end is a standard 15 Pin VGA (RGB type) connector that I have tried on all three of the 15 pin connections on the back of my SHARP projector. In each case I am getting a "No signal" Message.
    I have already verified that the all 3 of the 15 pin inputs work because I can get an RGB signal from a computer to the projector and that will display just fine.
    I have already set the internal settings on the DVD menu to "Progressive Scan" as opposed to "S-Video"
    Does anyone know if the XR-10X supports progressive scan, and/or what the problem could posibly be.
    Thanks HTMD (Home Theater in Maryland)
