Sharp XG-NV7XE Help needed
Discussion in 'Projectors, Screens & Video Processors' started by Dubbing Mixer, Aug 9, 2002.
  1. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    Does anybody know how to get into the service menu on this Sharp? I'm looking for how you reset the bulb timer.
    Any assistance would be much appreciated!
  2. Vis Man
    Vis Man
    Feb 22, 2001
    207
    UK
    +10
    On Older models to reset the lamp counter there was a button sequence
    With the projector on, hold the right arrow, down arrow and enter key down cut the power dead. with the three keys still pressed down power back up. After the lamp has come back on you should read on screen Lamp reset 000.
    Try this not 100% sure if it will work
  3. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    Many thanks! We'll give it a try!
  4. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    BUMP!
    Any other suggestions, please, in case the above doesn't work.
