Sharp XG-MB55X Multi Media Projector
slaurie
Sharp XG-MB55X Multi Media Projector £250
This projector is still unopened in its original box
Sharp XG-MB55X ... remarkably affordable price. With 2500 ANSI Lumens and XGA resolution, the XG-MB55X is perfect for educational and meeting room settings, and with its high image quality (2000: 1 contrast ratio) and wide compatibility, the XG-MB55X is ideal for use with both high resolution computer and video sources (including HDTV). Further, the XG-MB55X features an on-board RS-232C port with the frequently required RS-232C control adapter conveniently included "in the box".
Product Description: Sharp XG-MB55X - DLP Projector
Device Type: DLP Projector
Built-in Devices: Speaker
Dimensions (WxDxH): 31.5 cm x 29.5 cm x 11.9 cm
Weight: 3.9 kg
Image Brightness: 2500 ANSI lumens
Image Contrast Ratio: 2000:1
Resolution: XGA (1024 x 768)
Native Aspect Ratio: 4:3
Lens: Short-throw zoom lens
Bulb type: SHP 275 Watt
Bulb life cycle: 2000 hour(s)
Video Input: RGB, S-Video, composite video, component video ( NTSC, SECAM, PAL ) - DTV
Video Output: RGB, component video
Audio Output: Speaker(s) - integrated
Sound Output Mode: Mono 2 Watt
Input Device: Remote control
Power: AC 120/230 V ( 50/60 Hz )
Power Consumption Operational: 350 Watt
Expansion/Connectivity
Interfaces: 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) ¦ 2 x audio line-in - mini-phone stereo 3.5 mm ¦ 1 x component video / RGB output - 15 pin HD D-Sub (HD-15) ¦ 1 x S-video input - 4 PIN mini-DIN ¦ 1 x composite video input - RCA ¦ 1 x audio line-in - RCA x 2 ¦ 1 x serial RS-232C - 9 PIN
mini-DIN
Projector/Panel
Display Format: 786,432 pixels
Features: Intelligent Image Resizing
Image Aspect Ratio: 16:9, 4:3
Image Size: 100 cm - 762 cm
Max Resolution: 1024 x 768 (native) / 1400 x 1050 (compressed)
Max Sync Rate (V x H): 85 Hz x 70 kHz
OSD Languages: English, German, French, Italian, Portuguese, Swedish, Spanish, Dutch, Japanese, Chinese, Korean
Projection Distance: 1.4 m - 12.1 m
Uniformity: 85 %
Video Bandwidth: 108 MHz
Video input
Analogue Video Format: NTSC, SECAM, PAL
Analogue video Signal: RGB, S-Video, composite video, component video
Digital Video Format: DTV
Video output
Analogue Video Signal: RGB, component video
Please let me know if you have any further questions
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
