Sharp, which one?
Discussion in 'LCD & LED LCD TVs Forum' started by stvn, Feb 6, 2005.
Tags:
  1. stvn
    stvn
    I have a doubt, since friday I have an Sharp AQUOS GA4 32" for testing and with the film King Arthur in DVD conected with the RCAs (no progressive scan), the image is not too good, the colours and details are rare and sometimes flick.
    ¿Its normal?.
    Another question. The price for GA4 is 2.577 Eur and for GA5 is 2.333. If i am in true, the only difference is that GA5 don´t have the DVI input but nothing else diffence. Is so important DVI to pay 244 Eur more for it?.
  2. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    Try a GA4 on DVI it will blow you away. Definate improvement over component.
    Prog scan will improve things though.
    Remember no DVi on a GA5 ...............................
  3. jimg
    jimg
    Jul 4, 2004
    826
    +58
    There a quite a few differences between the 2 and I posted them a while back. Go for the GA4.
  4. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Stvn,
    When you say connected through RCAs, do you mean Component input (3 video cables) or composite input (1 video, 2 audio).
    Richie.
  5. stvn
    stvn
    HI
    I mean composite input
  6. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Make sure you are using RGB, component or DVI. Short of a modulated RF signal, composite is the worst of the lot. It may be simply a matter of selecting RGB output in your DVD player and using a SCART lead into an RGB enabled SCART socket on the display.
  7. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Yep, agree with Ian. I'm guessing you don't ahve component as you don't have Prog Scan (They seem to go hand in hand) so the least you can do it connect via SCART and enable RGB on the DVD player and on the input to the TV. Remember that on;y inputs 1 and 3 on the Sharp can receive RGB. Input 2 cannot.
    As an alternative, try connecting the DVD player to the Sharp by an S-Video lead. RGB Scart and S-Video are nearly the same PQ (Which one is better depends on the system) but S-Video is better than composite.
    Richie.
