Sharp v Tosh
Discussion in 'LCD & LED LCD TVs Forum' started by Shall, Jan 5, 2005.
Tags:
  1. Shall
    Shall
    Hi guys
    The Perfumed Ayatollah has just released some post-Xmas cash, so the home cinema / computer room can progress.
    The new LCD will be viewed at about 8ft as a telly, and "normal" distance on a desk as a PC monitor. That being the case, I thought 26" / 16:9 would be the largest sensible compromise.
    After reading countless tests, and this forum, I had narrowed the search down to Toshiba 26WL46 and Sharp LC26GA4E. Specific points to consider:
    As I will be sitting close to the screen as a PC, I am not worried about full screen display - in fact, it could make my eyes go funny. As long as I get the equivalent of, say, a 17" TFT, I'd be happy.
    As a telly/DVD display, I obviously want the best piccy I can get, least smearing etc etc, and the most future-proof. I like the idea of a separate connection box which I think the Sharp has, if it means a single tidier cable up to the screen.
    And of course, I like a bargain if there is one going!
    Any comments would be greatly appreciated.
    Steve
  2. andya
    andya
    Oct 25, 2002
    2,432
    48
    manchester
    +35
    simple sharp
  3. Yaka
    Yaka
    Dec 20, 2000
    1,758
    2
    63
    +135
    sharp will let you use full res via dvi port the tosh wont. so sharp
