sharp tv - help - how to setup to auto find scart input
LSDAV
Can anyone help ive got a sharp tv ( dont know model about 3/4 years old) when you turn it on because its hooked up through the scart leads you have to manually select the input each time. its not a big deal but surely there must be a way of setting it so it automatically finds the correct scart from the sky box?
I will try and get the model number if it helps.
Cheers in advance
JayCee
There isn't I'm afraid...I know the model in question and it's a crazy design...having to select front/rear etc with the fastext buttons. :thumbsdow
