sharp tur160 recording problem!!!
Discussion in 'Digital TV & Video Players & Recorders' started by dbrad, Jan 30, 2009.
Tags:
  1. dbrad
    dbrad
    Jun 3, 2003
    80
    9
    audenshaw, manchester
    hi
    i have the above pvr but have a problem, the signal strength is 60% out of 100% on most channels and a quality pic, but when i try to record something it comes up with 'signal strength too weak!!' i have done software updates tried an attenuator to no avail its a new aerial and wiring, i have recorded on the pvr in my old house but im sure its not the signal thats the problem, any ides anyone???
    cheers
  2. clemenzina
    clemenzina
    Jun 25, 2006
    1,542
    SW London
    +135
    For starters, tell Wolfbane your postcode and they'll tell you what sort of aerial you need:
    UK analogue TV reception predictor
    And someone else may come along soon and help.
    clemenzina :)
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,733
    Somewhere in South Yorkshire
    +6,310
    I suppose it's possible that - as this is a twin-tuner device - the tuner being used for "live" reception (and what you are seeing when you look at the strength/quality measure) is performing better than the other tuner used for recording. This may be a matter of marginal signal and slightly different sensitivities, or it may be that the second tuner has become disconnected from the aerial (is it external on this box?) or has deteriorated/broken in some other way. Possible explanation, but not necessarily very helpful, I guess.
  4. nvingo
    nvingo
    Nov 29, 2007
    3,143
    Cambridgeshire
    +717
    Yes the Sharp PVRs are Vestel hardware, which have four aerial sockets, input to tuner one, passthrough (out and in) to tuner two, and TV out from tuner two.
    If during the move the passthrough loop was disconnected (or incorrectly re-connected), there lay your problem.
