sharp pgm20x
Discussion in 'Projectors, Screens & Video Processors' started by tahirti3, Dec 18, 2003.
  1. tahirti3
    tahirti3
    Sep 18, 2002
    1,494
    48
    +26
    how can i get a pal progressive picture from my pj?the listed specs are 480 i and 480 p,720p and 1080i.it plays ntsc progressive without any problem.i have the denon dvd 2800 mk2.
  2. amordue
    amordue
    Nov 13, 2002
    101
    Edinburgh
    Not sure you can, I have the same projector, and its getting pretty old now, inthe world of fancy new projectors (18 months something like that), which is from before the PAL progressive standard was decided upon, so chances of it supporting it are probably quite low.
    I haven't had a chance to connect any PAL progressive stuff up to it, as I use DVI from the HTPC and GC outputs 480p, you might just have to live with interlaced component signal :( for PAL disks for the moment.
    I'll see if I can borrow some PAL progressive source and give it a go on mine.
    Alex
