Sharp LC32P50E HDMI PC input??
J
jimexbox
Hi Everyone, I would appreciate it if anyone could tell me if you can connect a PC (purely for games) through the HDMI input.
Thanks in advance.
8472
Thanks in advance.
Yes - you may need a HDMI to DVI cable though. :lesson:
Jim Barry
This TV is simply not designed to be connected to a PC. If you do try it, you will get a 720x576 mode with cropped edges and the pixel mapping will not be 1:1 horizontally either. You can try mucking around with custom modes in Powerstrip, but it didn't do me much good. You're probably better off using TV-out for gaming.
