Sharp LC32GD1E Card adaptor Advice?
Discussion in 'LCD & LED LCD TVs Forum' started by prologica, Mar 3, 2005.
Tags:
  1. prologica
    prologica
    The Sharp manual is not particularly helpful on the type of PC card adaptor to use to view camera memory cards. There are 3 different memory types in the family - Compactflash, SD and Smart Media - a shame because it seems the 4in1 and 6in1 card adaptors support all these except Compactflash! (unless anyone knows otherwise?)...
    But the main point is, does any PCMCIA card adaptor , suitable for the memory card of course, fit the bill? I found a Compactflash card adaptor for just 3.99 incl delivery at the MX2 website but it talks about being suitable for machines with suitable operating systems and additional drivers may be required for NT systems. Now I know what this all means in relation to a PC but how does it relate to a TV card slot?!...is it ok or do i need to find one that is truly plug and play?
    Over to you guys!
    David
  2. alscds
    alscds
    as far as im aware any card adapter is suitable the only specifics relate to the type of memory card you are using so obviously with a compact flash card you would need the compact flash card adapter. our sharp rep gets his from maplins £17
  3. paulduckworth
    paulduckworth
    Jan 11, 2005
    37
    The one I use for my GD1 is a Kingston 4 in 1 - SD, MMC, SM and MS. I got it from savastore.com. I think I paid too much for it though, about 25 quid. I was in too much of a rush to shop around for it.
    It works fine in the TV. I would have thought that any PCMCIA card would be fine in the GD1.
  4. prologica
    prologica
    Great help as always! Thanks guys.
