Hi, I have just got my Kenmark KM-TS02M stand from John Lewis ahead of getting a Sharp LC32GA6E next week. The TV stand is 677W x 307D (mm) and the Kenmark is W80 x D40cm, now is seems a daft question as it sounds like it should fit ok but does anyone know how far if anything the Sharp LC32GA6E sticks out at the back so to speak, I'm not too sure what the shape the stand is. Will it fit? cheers
I too have the Kenmark KM-TS02M, have a 32" Acer LCD, fits perfect, looks great and far cheaper than the Alphason, it could easily accomodate a 37" LCD so no worries there. The only problem I found was the width of the rear 2 Steel supports, they taper in and leave a 42cm wide space, problem I had was that my HTPC case is 43.5 cm wide the same as standard AV equipment, so as long as you have no really deep AV/Hi-Fi seperates, should have no probs.
Thanks for that mate. I wonder how big your Acer LCD stand footprint is compared to the Sharp? I won't be adding any Hi-Fi stuff to the unit so that will be ok.
The sharp website has a download of a spec diagram for the 32lcgd1e (same dimensions as the GA6/7). This includes all dimensions including the those for the stand / base etc.
