Sharp LC32GA5E PC connection
Discussion in 'LCD & LED LCD TVs Forum' started by Starfish_001, Apr 1, 2005.
Tags:
  1. Starfish_001
    Starfish_001
    Has anyone actually tried Sharp LC32GA5E with a PC connection running 1366x768 and one to one.
    Sharp say that it has a max res of 1280* 768 from PC. I cant't find a manual for this model. Other Sharps state support in the manuals
    Sharp also said that the max res for the GA3, GA4 and GD1 is the same. But the manuals claim support and people seem to have this working here
    http://www.avforums.com/forums/showthread.php?t=168317&page=2&pp=15
    Anyone
  2. Black Custard
    Black Custard
    Hi Starfish..
    Problem with the 5 series is that it does not have a dvi input, this makes connecting up a pc a real pain, you might be able to do it at SVHS :( but I would not fancy you would get much of a result...
    The sets referred to in the link that I can see are 4 and 3 series that have the DVI input :thumbsup:
  3. jerkyboy
    jerkyboy
    This model has a standard analogue PC VGA input.
    It could not be any easier to connect your PC, just plug it in and the Sharp will recognise it.
  4. Starfish_001
    Starfish_001
    jerkyboy,
    Thanks that was my understanding atandard Dsub - ckeced inthe shop this morning.
    But my main concern is resolution - Do you know the max resolution it can support. because alot of sets can't support more than 1280 from a pc.
    If someone has a manual can they have a look at the supported PC resolutions please - normally about 6-10 listed :lease:
  5. Rob1698
    Rob1698
    The manual is online on the website, isn't it?
  6. imh
    imh
    No manuals on the web for the ga5s for some reason.
  7. Starfish_001
    Starfish_001
    I looked every where before asking and could find no manual
  8. captaindobie
    captaindobie
    Apr 17, 2002
    592
    Scotland
    +21
    I have just checked the manual for you.
    PC compatibility chart is as follows...
    VGA (640 x 400) (720 x 400) (640 x 480)
    WVGA (848 x 480)
    SVGA (800 x 600)
    XGA (1024 x 768)
    WXGA (1280 x 720) (1280 x 768)
    SXGA (1280 x 1024)
    Vertical frequenc y 60hz for all of the above.
    As an addition, is there any real advantage in connecting standard home cinema kit (DVD player, SKY+ etc using RGB scart output) into the Analogue PC input on this TV? (not even sure if this is possible anyway!)
  9. Starfish_001
    Starfish_001
    captaindobie
    Thanks that means my choices have now changed
    LC32GD1E vs Relisys RLT3200
    My intention is to connect a Media PC, not standard Hifi stuff into the Dsub.
    Back to the drawing board I guess
  10. gslater
    gslater
    Mar 18, 2005
    129
    London
    +3
    On the subject of connecting AV sources to your LCD....I was previously looking to get a plasma and was told that the best picture from a sky source is to use scart to VGA.....but you will need to get a decent quality cable which does this....JS Technology is the most commonly cited one.
    I purchased the sharp 26" GA3E as an interim measure before getting the larger plasma...I also plan to connect a PC in the future...that is why I went for the GA3E...the DVI connection is best.
  11. Rob1698
    Rob1698
  12. Zagge
    Zagge
    Jan 7, 2005
    25
    I think someone mentioned elsewhere on the forum having succeeded with 136x/768 resolution with VGA (even though not mentioned on manual it seems ??)
    Can anyone confirm this?
    Is it possible to get a 1:1 pixel mapping or at least in overall, a decent picture from PC?
    By the way,manual for english can be found here (I was unable to get direct link to it).
    http://esupport.sharp.at/html/om/index.php?ProdLine=11&TemplateLang=de
    Zag
