Sharp LC30HV4E Windows XP Driver ???
Discussion in 'Plasma TVs Forum' started by jerkyboy, Aug 15, 2004.
  1. jerkyboy
    jerkyboy
    Where can I download a driver for this LCD TV.
    Does anyone know.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Why would you want an driver for a TV????
  3. jerkyboy
    jerkyboy
    This is a TV and a monitor dummy.
  4. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,522
    Kent
    +830
    Dummy? That's not nice.
    If you are trying to get your graphics card to send the LCDs native resolution of 1280 x 768 to the telly and it's not doing it then download a program called Powerstrip. This will allow you to get your graphics card to output resolutions it usually won't. The Sharp will only accept 1280 x 768 @ 60Hz.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    This is not a peice of IT hardware, it is a TV if you want to set your PC to output onto said TV suggest you upgrade your graphics card driver to set output to 1280X768, 60Hz or download powerstrip as suggested by liam.
