Sharp LC30HV4E, direct DVI connection ?
Discussion in 'LCD & LED LCD TVs Forum' started by jerkyboy, Nov 4, 2004.
Tags:
  1. jerkyboy
    jerkyboy
    Can anyone tell me if its possible to bypass the media box on my Sharp LC30HV4E LCD and connect a DVD player (Denon 1910) via the DVI connection.
    I assume thats what type of socket it is on the back of the Sharp, but I am not sure.
    If its is possible, what sort of input options would I get when the LCD is turned on ?.
    Thanks for any info.
  2. Skiny
    Skiny
    Aug 18, 2004
    287
    19
    I didn't think the LC30HV4E has a DVI connection.
  3. jgrg
    jgrg
    Oct 19, 2004
    560
    28
    Cambridge
    +36
    I have contemplated the same thing myself.
    I've seen these connections between the media box and the screen. They are definitely DVI connectors, and might work as PC DVI connections, but you would only find out by testing.
    I think the chances that they are HDCP compliant are low though, and without HDCP the DVD player won't work.
    James
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    It doesnt but thetuner attacje to the screen by a DVi type cable ( aPC should be able to cope) but unlikely Denon will work as it would need to match screen native res and refresh rate which i dont think it is possible to do with the denon
