Sharp LC26GA5 - Cable management etc etc
Discussion in 'LCD & LED LCD TVs' started by ianjh, Mar 10, 2005.
  1. ianjh
    ianjh
    Mar 5, 2005
    83
    Norwich
    Seriously considering one of the above - can anyone confirm what type of cable management this set has?
    I believe the GA3 system held cables in the upright of the stand - if so does it accomodate all the cables - 2 scart - component - aerial - power etc.
    Also apparently the stand does not swivel like the GA3
    Best price i can find is £850 inc delivery from digital direct.
    ianjh :lease:
  2. LcdGuru
    LcdGuru
    aquos.co.uk used to have technical drawings in pdf format - you might still be able to find them on there.
    I believe the 26" has a channel for cables in the stand + removable plastic panels on the back of the set. Plenty of room for all your cables - and looks very tidy when done correctly.
    If the stand doesn't swivel that sucks. My GA4 stand swivels a few degrees and it's a very useful adjustment.
  3. ianjh
    ianjh
    Mar 5, 2005
    83
    Norwich
    Thanks for your response - i have tried to obtain the pdf for this set - the GA4 and GA3 are available but not the GA5 for some reason.
