Sharp LC26GA4E wall bracket
Discussion in 'Home Cinema Buying & Building' started by naisy, Mar 8, 2005.
  1. naisy
    naisy
    Can anyone recommend a wall bracket for use with this LCD
  2. blossom
    blossom
    Feb 15, 2004
    1,289
    41
    Solihull
    +14
    Try this .
    It worked for me. Went up a treat.
    Paul
  3. Blakey
    Blakey
    Do I need any extras for this or just the item you linked to?
    Blakey
  4. blossom
    blossom
    Feb 15, 2004
    1,289
    41
    Solihull
    +14
    Just think that you need the bolts to screw it on to the wall.
    I don't think they came with it.
    Paul
