Sharp LC26GA4E NTSC playback
Discussion in 'LCD & LED LCD TVs' started by phoenix69, May 9, 2005.
  1. phoenix69
    phoenix69
    Hi all,
    Was thinking about buying LC26GA4E mainly for watching tv, but also for my xbox and PS2 and was wondering if it plays NTSC format gams and dvds, as i've not seen it mentioned on any reviews of the tv
    Also out of these two which LC26GA4E or the newer LC26GA5E are better.
  2. peahead
    peahead
    Dec 14, 2002
    2,836
    St.helens
    +268
    yes it will play ntsc fine and the ga4e is the best one to go for.
  3. thfccambs
    thfccambs
    Jul 17, 2002
    18,957
    White Hart Lane
    +5,010
    No problems at all m8,its also a great LCD.Think you will be luck if you can find a LC26GA4E though.The LC26GA4E is better as it has DVI,the GA5 dosen't support HI-def.
