Sharp LC26GA4E & Denon 1910 = no sound??
Discussion in 'LCD & LED LCD TVs' started by Pezerinno, Aug 2, 2005.
  1. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,411
    71
    Southsea
    +70
    Hi guys, hoping you can help me out. In my bedroom I have a sharp 26" GA4E widescreen LCD telly hooked up to a Denon 1910 DVD player. As its just in my bedroom I'm not using an external receiver/speakers just the stereo ones supplied with the TV. I have the Denon player via a DVI-D cable - the picture is great. I have used the supplied audio cable and have that connected from the DVD player to the TV yet I'm not getting any audio.
    My freeview PVR is connected by scart and has audio fine so the telly isn't at fault. Not sure if I have to change come settings on the DVD player or the TV...
    All help appreciated.
    Thanks, Nick.
  2. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
    I think there is a setting on the Sharp TV which assigns the audio inputs to different video inputs. Have a look through the set up menus on the Sharp and you should find it.
  3. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,411
    71
    Southsea
    +70
    I can't seem to find anything like that in the menu's or in the Sharp manual ??
  4. dsb
    dsb
    there's more than 1 audio input - did you try connecting to the pc audio input seeing as you are using the dvi input?
  5. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,411
    71
    Southsea
    +70
    Is there a PC audio input? I thought there was only one audio output and one input.
  6. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
  7. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,411
    71
    Southsea
    +70
    Looks like you're correct. Didn't see that one hidden down there!
